Part Number: LM4880
Other Parts Discussed in Thread: TPA6111A2
I'm working on a product which includes a headphone amplifier, using an LM4880M. I'm producing a low-frequency signal using a DAC, which feeds into the LM4880M. I'm seeing significant noise/instability on the output of the amp.
As you can see, I added in-the-loop compensation. The first revision did not have this compensation. Adding the compensation did not reduce the noise. Here's what the noise looks like:
If instead of connecting headphones, I connect a dummy load of 47R before the output capacitor, then the signal is clean.
With the DAC at a fixed output, I still see similar noise in the output. If I put the amp into shutdown, then the output is clean.
