TPA6138A2: How to describe output impedance
Part Number: TPA6138A2
Hi team,
I learn it from E2E, output impedance is defined by Po plot. What is the conversion equation from output power to output impedance?
Hideki
  • Hi Hayashi-san,
    To know the output impedance you would need to set a known load, then analyze ratio of change in output voltage compared to a change in load current.
    Perhaps Spice model can be used to get an estimated value.
    -Ivan Salazar
    Applications Engineer
