PUREPATHCONSOLE: Low Shelf Filter and Bass Shelf Filter Difference?
Part Number: PUREPATHCONSOLE
Hi Team,
I have questions about Low Shelf and Bass Shelf Filter.
  1. What's difference between Low Shelf and Bass Shelf? Are they only different in Q settings?
  2. What's the order of Bass Shelf Filter?
Would you share a relevant materials if you had?
Thank you always,
Jay
  • Hi Jay,
    A bass shelf is a high pass filter that rolls off ideally infinitely from the cut off frequency. A low shelf rolls off from a cutoff frequency but returns eventually to a constant magnitude. See the picture below for an example:
    The Q factor controls how steep the transition band is. Because the bass shelf continues ideally to 0 Hz, there is no Q factor.
    The order of the filters will likely be in the documentation/user guide of whatever part you're using.
    Jeff
  • Hi Jeff,
    Thanks for your reply. However I tried to search every documentation and couldn't find any filter information .
    But from what I found on PPC3, It seems that Bass and Low Shelving filters are 2nd order filters which has two poles respectively. Am I correct?
    And for Bass shelf filter, you said it rolls off ideally infinitely like high pass filter. But it seems more acting like a Low shelf not high pass. Could you share more detailed information if you don't mind?
    Jay
  • Hi Jay,
    Thanks for clarifying what you're seeing. It's likely then that the difference is only a naming convention for the script that is running in the background. They are certainly second order, and are most likely biquad filters. The bass shelf likely lacks the Q parameter since the bass shelf is typically at the very bottom of the frequency response and used more like a cutoff than a shelf.
    Jeff
  • Hi Jeff,
    Thanks for your confirmation!
    Jay
