Other Parts Discussed in Thread: TAS5412-Q1, TAS5412
Hi team
1.I downloaded the TAS5411-Q1 PSpice model form TI website in that zip file TAS5412-Q1 reference design is there, i am trying to run this file but i am getting below error --attached, in this folder only TAS5412-Q1 .lib file is there but i need TAS5411-Q1
2.and when i am trying to use the .lib file, .OLB file of TAS5411-Q1 but after adding them library files in the library i am able to see the TAS5412-Q1 in the part numbers, but i need the TAS5411-Q .lib, OLB files please share them thank you.
Please correct me if above is wrong
**** 04/02/22 22:26:41 ****** PSpice 17.2.0 (March 2016) ****** ID# 0 ******** ** Profile: "TAS5411-Q1_TestBench-sd" [ c:\users\na65357\documents\thales_derisk\board-2\analog_audio_work_progress\simulations\spe **** CIRCUIT DESCRIPTION ****************************************************************************** ** Creating circuit file "sd.cir" ** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS *Libraries: * Profile Libraries : * Local Libraries : .LIB "C:/Users/NA65357/Documents/TAS5411-Q1_PSPICE_AIO/TAS5411-Q1.LIB" * From [PSPICE NETLIST] section of C:\Users\NA65357\cdssetup\OrCAD_PSpice\17.2.0\PSpice.ini file: *Analysis directives: .TRAN 0 1ms 0 .OPTIONS ADVCONV .PROBE64 V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*)) .INC "..\TAS5411-Q1_TestBench.net" **** INCLUDING TAS5411-Q1_TestBench.net **** * source TAS5411-Q1 C_C13 OUTP2 0 680n TC=0,0 R_R4 OUTN2 OUTP2 4 TC=0,0 L_L1 OUTP1 OUTP2 22u L_L2 OUTN1 OUTN2 22u C_C12 OUTN2 0 680n TC=0,0 E_E2 N1154562 0 N115506 0 -0.5 C_C1 N1154322 IN_P 1u TC=0,0 C_C2 N1154562 IN_N 1u TC=0,0 V_V9 N115506 0 +SIN 0 0.167 1k 0 0 0 E_E1 N1154322 0 N115506 0 0.5 V_V1 PVCC 0 14.4 X_U2 PVCC PVCC PVCC 0 IN_N IN_P 0 OUTN1 OUTP1 PVCC PVCC PVCC PVCC PVCC + TAS5421-Q1 **** RESUMING sd.cir **** .END ERROR(ORPSIM-15108): Subcircuit TAS5421-Q1 used by X_U2 is undefined
