Part Number: TAS5760M
Good Day. I have a customer who is working with TAS5760. Please see below his query for your reference. Thank you very much.
1) Is software register map is same for both the ICs. Is register setting generated for TAS5760MDDCA with EVM board can be used with TAS5760MTDAPQ1?
2) My desired use case is mono mode 16-16bit data. SCLK = 32 * sampling rate. What is the desired MCLK frequency for the audio Amplifier
3) Can describe about software and hardware mode. I need to control i2c. So what mode is suitable and how to achieve it.
Ray Vincent
