Hi team,
When the IC switches to the mute state, a pop noise is generated, is there any solution to solve this ?
Hi team,
Hi Hazel,
Can you please double check if soft-stepping feature is enabled?
This is controlled by Page 0, Register 0x3F, bits 1-0.
If this feature is disabled, you may try to enable and check if pop performance improves.
-Ivan Salazar
Applications Engineer
Hi Ivan,
thanks for the advice, I'll try it, but one more question here, could you please explain the internal mechanism ?
Hi Hazel,
You can find more details in this appnote: https://www.ti.com/lit/ug/slau472/slau472.pdf
Specifically section 2.4.2.2
-Ivan Salazar
