TLV320AIC3204EVM-K: Setting up the TLV320AIC3204EVM-K for streaming audio tests
Part Number: TLV320AIC3204EVM-K
I have the TLV320AIC3204EVM-K board and I'm having a bit of trouble figuring out how to get started. I was able to get the GUI installed on my Windows 7 computer (I had to run the software in compatibility mode as was suggested in the TLV320AIC3204EVM-K user guide). I would like to stream audio in real-time while changing the configuration settings, so I can see how the audio signal changes with each new setting. I was able to get some streaming audio in the automatic gain control configuration window, but that was showing me a gain vs. frequency plot, while I was more looking for a time-domain plot. Is real-time signal viewing and analysis possible with this particular evaluation board and GUI? I'm new to the audio processing realm, so I'm just trying to get a feel for things and learn by doing a bit.
I've attached the version of the user guide that I am referencing as well as the evaluation board's purchasing link on Digi-Key:
www.digikey.com/.../2047763
Any help you could provide would be appreciated.
Thank you.
slau266a.pdf
  • Hi Orlando,
    Unfortunately, our GUIs generally don't have time domain plots like that. We recommend you use a free software like Audacity or Goldwave to take time domain measurements of signals. From there you can select the EVM as an audio device and record digital audio data.
    Jeff
