Part Number: TAS2563
At present, two tas2563rpps are connected to the same I2S. If one pa wants to receive the left channel data of I2S and the other pa wants to receive the right channel data of I2S, how can this pa end be controlled.
Just to let you know today was a holiday in the US, so we will get back to you on July 5th. However, the best way to configure which channel of audio is selected is to use PPC3 to generate the register configuration, do you have access?
Hi Tony,
As Brian mentioned below, the best way to configure the device is by generating the configuration files from PPC3, you can request access to this software tool within TAS2563 product folder: https://www.ti.com/licreg/docs/swlicexportcontrol.tsp?form_id=272827&prod_no=TAS2563-SW&ref_url=asc_amps_lpaa
I2S input data is handled by register TDM_CFG3 (page=0x00 address=0x09) and TDM_CFG2 (page=0x00 address=0x08):
And regarding the driver, you may refer to our latest reference codes in our repo: https://git.ti.com/cgit/?q=tas2563
-Ivan Salazar
Applications Engineer
This is the startup log and the log of playing music. Can you help me see what the problem is? At present, I2C and I2S are OK, mainly the operation of PA side registers and the loading of firmware.
Hi Tony,
I'll take a look at the log file you shared and send back some comments within the next day.
-Ivan Salazar
Hi Tony,
Not sure if you got this issue taken care of outside of this thread, please let us know if you still need assistance.
Brian
Hi Tony,
Please let us know any updates on the status of your project, and also if we should follow up on either of these threads:
-Ivan Salazar
