Part Number: PCM5242
Hi team,
I have a question for PCM5242 design.
#1. LDOO and DVDD bypass capacitor.
I plan to apply 3.3V to DVDD (IO=3.3V) and to use internal LDO for 1.8V.
In this case, could you recommend the amount of bypass capacitor on DVDD and LDOO pin?
Is it OK to just fed 0.1uF to LDOO?
(It is described to use 10uF in parallel with 0.1uF for DVDD=LDOO=1.8V case in datasheet P60, Figure 80.)
regards,
