Part Number: PCM2706C
Other Parts Discussed in Thread: PCM2706
I have a schematic with PCM2706C, where it functions as a USB <-> I2S bridge, that would need a review. There has been some debate on the size of the capacitors by the crystal, and if they should be smaller or bigger. The load capacitance of the crystal is 20 pf, so to achieve a 5 pf capacitance for the board, the caps should be even 30 pf. Is it possible to use larger (20-30pf) capacitors by the crystal, or do they need to be smaller?PCM2706C Schematic.pdf
