AIC3254 Dual Mic Noise Cancelling
I am planning to use the AIC3254 for active noise cancellation in a 90db noise environment inside an aircraft. Is the dual mic algorithm sufficent to perform well in this kind of environment. I would like to know if we can get the low level block of the dual noise mic block that is provided so that we can customize it for our use case. Also are there any better alternatives that can be used other than the AIC3254 (this has a 93dB SNR ADC and am not sure if this could be a blocking factor)
Yogender
