TAS6424E-Q1: THD clip setting
Part Number: TAS6424E-Q1
It is said in the datasheet "Clip detect is reported on the WARN pin if 100% duty-cycle PWM is reached for a minimum number of PWM cycles set by the Clip Window Register (address = 0x23)."
I want to confirm the relationship between the setting value and the THD value. Is 20 PWM cycles represent 5% THD? Is there any function relationship? Thanks.
