Part Number: TAS5828M
Hi Team,
As below function block, please help provide TAS8528M multi-channel amp application reference schematics, thanks!
Hi Team,
Hi Kevin
we don't have the multi-channel schematic now.
but below information maybe help you.
1. address setting for each device. customer can set address for each amplifier following below table.
2. about the schematic reference, you can refer below 1st link. it uses i2s and 2 amps with different address. you can refer it and expand it to 6amps with different address.
the circuit about how to set each device's address is same. the other surround circuit you can refer the tas5828 schematic in the datasheet or the schematic in below second link.
thanks.
jesse
