Part Number: TAS5825PEVM
I have two questions for TAS5825PEVM.
1. TAS5825PEVM used LM5155D GPIO1_Hybrid_Pro to adjust output voltage?
2. Does there have TAS5825PEVM process flow can share to me?
Thanks!
Jeff
Thanks!
Jeff
Hi Jeff
thank you for your question.
1.yes, your are right. we use it on our EVM board. you can refer below link for reference. But other boost should also work.
2.about the process flow, it is still ongoing.
except hybrid-mode, some module's description you can take a reference the document in below link.
About hybrid mode, maybe below link can help you.
thanks.
jesse
Hi Jesse,
My customer still have some question as below.
1. For hybrid-pro boost, how many input level or frequency will let hybrid-pro rise up voltage?
2. What is the condition to let hybrid-pro boost output voltage?
3. Is there any document for hybrid-pro detail?
Test method:
1. Input different level and different frequency to check output power consumption.
2.Using storage oscilloscope and digital multi-meter to monitor Hybrid-pro PWM and PVDD behavior.
Thanks!
Jeff
Hi Jeff
only input level will let boost rise voltage. 9 levels been set in the ppc3.
according to the setting in the ppc3, once the input level achieve a certain level, the boost output will increase.
for example: you can see below screenshot, there are 9 steps, you move your mouse curse to the graph, it will tell us how much voltage will trigger the next level.
below 2 links may help you.
i think your measurement method seems no problem.
thanks.
jesse
Hi Jesse,
Thanks for the information.
I have another question for below flow, as I know, I2S OUT and amplifier should both be behind of Crossbar(figure2), but in PPC3, show as below figure1.
Which one is correct?
Figure1:
Figure2:
Thanks!
Jeff
Hi Jesse,
There have few questions as below.
1.In figure1, Digital Gain setting from figure2 PPC3 GUI red mark?
2. As question 1, Digital Gain register is figure.5 DIG_VOL?
3. In figure1 analog gain adjust, is it in figure3 and figure4 mark?
Figure.1
Figure.2
Figure.3
Figure.4
Figure.5
Jeff
Hi Jeff
Yes, that's correct.
No, in this table, it's actually the DAC gain, and we don't suggest to change this value. The real Digital Gain is the Volume setting, in Book 8C, Page 0B, register start 0x0C for left volume and 0x10 for right volume.
This information should be contains in the Process Flow document. Sorry we don't have a document specially for 5825P, please use 5825M's Process Flow as a reference.
Yes, no problem about it.
Could you please raise a new Thread next time? We want to better management the E2E questions. Please don't reply in the too old Thread, also please raise a new Thread when we have different questions from previous one. Thank you.
