TAS5828M: After use, the output sound is very small
Part Number: TAS5828M
Now I have done prototype test using TAS5828MDADR, but the problem is that the sound is very low.
I'm not quite clear about the reason. Could you give me some suggestions? Is there any relevant configuration document that I can follow?
Many thanks~
  • Hi Gao
    thank you for your question.
    several possible reasons may need to confirm:
    1. considering does i2s signal be inputted normally.
    2. the gain setting in the DSP is too small or not?
    3. is the power supply for amps stable or not?
    BTW, can you provide some schematic and your current setting file in the amps?
    thanks.
    jess
