LM49450: LM49450
Part Number: LM49450
Hi
I was searching for the Code example or driver for LM49450 that i can use with our devices.
Boris.
  • Hi Boris,
    Unfortunately this is a considerably old part and there is not more information available other than what is included in the data sheet. I would suggest to check the default value for each register and check which ones you would need to adjust depending on the application requirements.
    -Ivan Salazar
    Applications Engineer
