Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
LM4871: Absolute Max Ratings of Vo1/Vo2
Part Number: LM4871
I cannot find the Absolute Max Ratings of LM4871's Vo1/Vo2 in the data sheet, however, how does the LM4871 behave if a voltage is externally applied to these pins when a supply to the LM4871 is turned off? Could it damage?
A voltage of about 2.5 VP-P can be applied between the Vo1 and Vo2 when it's turned off in the system.
Shinichi Yokota
  • Hi Yokota-san,
    Usually it is OK for analog input amplifiers if there's an input signal with a similar range as to when it's being powered. You may see some of your input signal passing through feedback resistor Rf.
    -Ivan Salazar
    Applications Engineer
