PCM4220
Other Parts Discussed in Thread: PCM4220
My customer has the following questions:
I will be using two chips as a slaves to a master clock source generated by a FPGA.  I want to know how internal sampling is synchronized to the external source?  I see two possibilities 1) The LRCLK only defines left / right channel data on the serial output port and the /RST pin aligns the digital filter or 2) The LRCLK aligns the internal digital filter.  I want to be sure that new samples output from the internal digital filter of both chips happen at the same time.
