Part Number: TLV320ADC6140
Hello all,
we are using the TLV320ADC6140 on our device. We generate from a DSP the I2S synchronisms for the device, but we are not able to make the device work properly.
The frequencies are non-standard and we will therefore want to configure the PLL manually. We also tried with frequencies compatible with the device, but if you do not enable automatic configuration it does not work.
We saw that in some tread to similar problems the solution with change the configuration on page 1, but we did not find any documentation to concern.
Where T found the documentation on page 1 of configuration? What other tests can we do?
Thank you very much in advance.
