Hi, Team
output is 3W/4ohm, 10uH+0.68uF, When boost enable, the test result is below
When boost disable
How to solve this problem?Thanks
Hi, Team
When boost disable
Hi Dillen,
There are a couple things I'd check:
-Ivan Salazar
Applications Engineer
Hi Ivan,
Thanks for your kindly reply.
Customer do enable, and add 10uH+0.68uF LC Filter @3W. Do we have a detailed EMI test report for demo board?
Hi Dillen,
EVM is not usually used for EMI testing, a special board with optical SPDIF interface would be required for that purpose (must consider that cables for both I2S/TDM and I2C switching signals should be avoided for EMI testing). Unfortunately I'm not aware of previous data captured for EMI on TAS2110.
-Ivan Salazar
