Hi, Support Team
Our customer Audio function use WM8960 will change to TAS2505-Q1
Could help to Confirm I2S data DACLRC(WM8960) is WCLK(TAS2505-Q1) are the same?
WM8960 |
TAS2505-Q1 |
DACDAT ---> |
DIN |
DACLRC ---> |
WCLK |
BCLK ----> |
BCKL |
MCLK ---> |
MCKL |
by the way our target speaker output impedance and max power as below spec, have any concern?
if any suggestion, Please advise me.
Lawrence
Hi Lawrence,
The pin description match correctly.
Regarding output power, this should be OK. TAS2505 should be able to output 1W for 12dB gain settings or higher:
-Ivan Salazar
Applications Engineer
