Part Number: PGA2500
Hi team,
I have a customer design in PGA2500 and found out that the schematic was wrong.
So do we have a latest one with the right version?
PIN CONFIGURATION
Hi team,
PIN CONFIGURATION
Hi Len,
The Pin Configuration and Pin Descriptions in the datasheet show the correct pin-out for PG2500. You may refer to these for accurate pin information.
Thank you for pointing out the error in figure 6, it appears that pins 18 and 19 have been incorrectly labelled "VA-" when they should be labelled "VA+". The pin numbers, wiring, and components are accurate however, as you can see they correctly connected VA+ to pins 18 and 19.
I will contact the publication team but it may be some time before the document can be updated. Until the corrections are published you may continue to reference figure 6 for a basic circuit configuration knowing that pins 18 and 19 of the PGA2500 are in fact VA+.
Zach
