TLV320ADC5140: About TDM data line no data output.
Part Number: TLV320ADC5140
Hi team,
Now I use two tlv320adc5140 to support 8 analog mic.But I have some problems.In TDM mode, tlv320adc5140 is slave.
After successfully writing to the register through i2c,the TDM data line has no data output.
I want to know if the current register configuration is correct?Why does TDM data line have no data output?
The register values are written as follows:
adc1: i2c address 0x4C
static struct DEV_REG adc1_reg_values[] = {
{ ADCX140_PAGE_SELECT, 0x00 },
{ ADCX140_SW_RESET, 0x00 },
{ ADCX140_SLEEP_CFG, 0x81 },
{ ADCX140_SHDN_CFG, 0x05 },
{ ADCX140_ASI_CFG0, 0x31 },
{ ADCX140_ASI_CFG1, 0xA0 },
{ ADCX140_ASI_CFG2, 0x00 },
{ ADCX140_ASI_CH1, 0x00 },
{ ADCX140_ASI_CH2, 0x01 },
{ ADCX140_ASI_CH3, 0x02 },
{ ADCX140_ASI_CH4, 0x03 },
{ ADCX140_ASI_CH5, 0x04 },
{ ADCX140_ASI_CH6, 0x05 },
{ ADCX140_ASI_CH7, 0x06 },
{ ADCX140_ASI_CH8, 0x07 },
{ ADCX140_MST_CFG0, 0x02 },
{ ADCX140_MST_CFG1, 0x48 },
{ ADCX140_ASI_STS, 0xff },
{ ADCX140_CLK_SRC, 0x10 },
{ ADCX140_PDMCLK_CFG, 0x40 },
{ ADCX140_PDM_CFG, 0x00 },
{ ADCX140_GPIO_CFG0, 0x22 },
{ ADCX140_GPO_CFG0, 0x00 },
{ ADCX140_GPO_CFG1, 0x00 },
{ ADCX140_GPO_CFG2, 0x00 },
{ ADCX140_GPO_CFG3, 0x00 },
{ ADCX140_GPO_VAL, 0x00 },
{ ADCX140_GPIO_MON, 0x00 },
{ ADCX140_GPI_CFG0, 0x00 },
{ ADCX140_GPI_CFG1, 0x00 },
{ ADCX140_GPI_MON, 0x00 },
{ ADCX140_INT_CFG, 0x00 },
{ ADCX140_INT_MASK0, 0xff },
{ ADCX140_INT_LTCH0, 0x00 },
{ ADCX140_BIAS_CFG, 0x60 },
{ ADCX140_CH1_CFG0, 0x00 },
{ ADCX140_CH1_CFG1, 0x0c },
{ ADCX140_CH1_CFG2, 0xff },
{ ADCX140_CH1_CFG3, 0x80 },
{ ADCX140_CH1_CFG4, 0x00 },
{ ADCX140_CH2_CFG0, 0x00 },
{ ADCX140_CH2_CFG1, 0x0c },
{ ADCX140_CH2_CFG2, 0xff },
{ ADCX140_CH2_CFG3, 0x80 },
{ ADCX140_CH2_CFG4, 0x00 },
{ ADCX140_CH3_CFG0, 0x00 },
{ ADCX140_CH3_CFG1, 0x0c },
{ ADCX140_CH3_CFG2, 0xfa },
{ ADCX140_CH3_CFG3, 0x80 },
{ ADCX140_CH3_CFG4, 0x00 },
{ ADCX140_CH4_CFG0, 0x00 },
{ ADCX140_CH4_CFG1, 0x0c },
{ ADCX140_CH4_CFG2, 0xff },
{ ADCX140_CH4_CFG3, 0x80 },
{ ADCX140_CH4_CFG4, 0x00 },
{ ADCX140_CH5_CFG2, 0xc9 },
{ ADCX140_CH5_CFG3, 0x80 },
{ ADCX140_CH5_CFG4, 0x00 },
{ ADCX140_CH6_CFG2, 0xc9 },
{ ADCX140_CH6_CFG3, 0x80 },
{ ADCX140_CH6_CFG4, 0x00 },
{ ADCX140_CH7_CFG2, 0xc9 },
{ ADCX140_CH7_CFG3, 0x80 },
{ ADCX140_CH7_CFG4, 0x00 },
{ ADCX140_CH8_CFG2, 0xc9 },
{ ADCX140_CH8_CFG3, 0x80 },
{ ADCX140_CH8_CFG4, 0x00 },
{ ADCX140_DSP_CFG0, 0x01 },
{ ADCX140_DSP_CFG1, 0x40 },
{ ADCX140_DRE_CFG0, 0x7b },
{ ADCX140_AGC_CFG0, 0xe7 },
{ ADCX140_IN_CH_EN, 0xf0 },
{ ADCX140_ASI_OUT_CH_EN, 0xf0 },
{ ADCX140_PWR_CFG, 0x00 },
{ ADCX140_DEV_STS0, 0x00 },
{ ADCX140_DEV_STS1, 0x80 },
adc2: i2c address 0x4D
static struct DEV_REG adc2_reg_values[] = {
{ ADCX140_ASI_CFG1, 0x80 },
{ ADCX140_ASI_CH1, 0x04 },
{ ADCX140_ASI_CH2, 0x05 },
{ ADCX140_ASI_CH3, 0x06 },
{ ADCX140_ASI_CH4, 0x07 },
