PCM9211: feasibility of using as input and output
Part Number: PCM9211
Other Parts Discussed in Thread: DIX9211, DIX4192
Hello There,
We are planning to use PCM9211 Audio Interface Transceiver on our products. would like to use the same part for different purposes in different product set. One of the products line uses the available input ports and other uses as Output, is it feasible?
 would like to know whether this part supports the following,
 As Inputs Device:
 Analog Aux input- One port
Optical Receiving Jack -One port
Digital Coaxial Input - One port
The Output shall be PDM, I2S Protocol
As Output Device:
 Analog Aux Output- One port
Optical Transmitting connector -One port
Digital Coaxial output- One port
The Input shall be PDM, I2S Protocol
Please share the details with available eval board and also suggest other optimal and cost effective solutions if available.
