Part Number: PCM1820Q1EVM
Other Parts Discussed in Thread: TLV320ADC5120, PCM5120-Q1, PCM1820, PCM1801
Hi Experts,
Just wanted to confirm if it is possible to select lower bitrates for the output signal? Can our customer select 16 bits for a Bluetooth module and 32 bits for high end audio equipment without adding components in between?
In case it's not possible. Which are our most common and tested 16-bit ADC for medium to high-end audio applications?
Thank you and regards,
Gerald
