MAX9768 nearest replacement
Hi Experts,
Good day! I need your assistance with the nearest possible alternative for MAX9768.
If none. Here are the other requirements below. Please suggest some ICs that match the below requirement.
-The gain requirement shall be between 4W-12W.
-speaker is 8 Ohm (1W nominal or 1.5W max power)
-Analog Input (Single Ended analog)
-Inbuilt volume control
-Input supply voltage  4.5V Nominal
Thank you in advance for your support.
Jonathan
