TAS2780: Debugging help needed
Part Number: TAS2780
I have two systems using the TAS2780, one development setup (using the TAS2780EVM) that is working fine and a PCB with an integrated TAS2780 which I cannot get to work.
The dev system has 12V on PVDD, the integrated setup has 20V on PVDD. VBAT1S has no external connection and should be generated internally. I adapted the jumper configuration on the TAS2780EVM to match the integrated setup.
schematics
I wrote some python code to set up power mode 2 and set the device in load diagnostic and in diagnostic generator mode and I can hear the beep on both systems.
After loading the kernel driver (which just resets and sets up power mode 2), I can play sounds on the dev system but on the integrated system there is no sound output.
Using the python script, I'm printing the content of the INT_LIVE and the INT_LTCH registers and I see slight differences between the two systems but I'm having difficulties interpreting them.
Here is the script I'm using: https://gitlab.com/-/snippets/2508725
I'm attaching the output of the script from both systems.
Can you help finding the problem?
Also, is the load calculation correct in the script? The spec sheet says the value is in Ohms but it looks more like Milliohms, the connected speaker is 8Ohm.
Is there any other diagnostics that I can run?
Thanks!
  Stephan
# Dev system (working fine)
***** Resetting
wrote reg 0x00 value 0x00, read back 0x00
wrote reg 0x7f value 0x00, read back 0x00
wrote reg 0x01 value 0x01, read back 0x00
read reg 0x02 (MODE_CTRL): 0x1a
read reg 0x03 (CHNL_0): 0x28
read reg 0x04 (DC_BLK0): 0x21
read reg 0x42 (INT_LIVE0): 0x00
read reg 0x43 (INT_LIVE1): 0x00
read reg 0x44 (INT_LIVE1_0): 0x00
read reg 0x47 (INT_LIVE2): 0x00
read reg 0x48 (INT_LIVE3): 0x00
read reg 0x49 (INT_LTCH0): 0x00
read reg 0x4a (INT_LTCH1): 0x00
read reg 0x4b (INT_LTCH1_0): 0x00
read reg 0x4f (INT_LTCH2): 0x00
read reg 0x50 (INT_LTCH3): 0x00
read reg 0x51 (INT_LTCH4): 0x00
read reg 0x52 (VBAT_MSB): 0x00
read reg 0x53 (VBAT_LSB): 0x00
VBAT1S Voltage: 0.000V
read reg 0x54 (PVDD_MSB): 0x00
read reg 0x55 (PVDD_LSB): 0x00
PVDD Voltage: 0.000V
wrote reg 0x00 value 0x04, read back 0x04
Load: 12607.650000000001 Ohm
***** Initializing power mode 2
wrote reg 0x0e value 0x44, read back 0x44
wrote reg 0x0f value 0x40, read back 0x40
wrote reg 0x00 value 0x01, read back 0x01
wrote reg 0x17 value 0xc0, read back 0xc0
wrote reg 0x19 value 0x00, read back 0x00
wrote reg 0x21 value 0x00, read back 0x00
wrote reg 0x35 value 0x74, read back 0x74
wrote reg 0x00 value 0xfd, read back 0xfd
wrote reg 0x0d value 0x0d, read back 0x0d
wrote reg 0x3e value 0x4a, read back 0x4a
wrote reg 0x0d value 0x00, read back 0x00
wrote reg 0x03 value 0xe8, read back 0xe8
wrote reg 0x04 value 0xa1, read back 0xa1
wrote reg 0x71 value 0x0e, read back 0x0e
read reg 0x03 (CHNL_0): 0xe8
read reg 0x04 (DC_BLK0): 0xa1
***** Running load diagnostic
wrote reg 0x02 value 0x13, read back 0x13
read reg 0x02 (MODE_CTRL): 0x13
read reg 0x43 (INT_LIVE1): 0x02
read reg 0x44 (INT_LIVE1_0): 0x19
read reg 0x4a (INT_LTCH1): 0x02
read reg 0x4b (INT_LTCH1_0): 0x19
read reg 0x51 (INT_LTCH4): 0x06
read reg 0x52 (VBAT_MSB): 0x26
read reg 0x53 (VBAT_LSB): 0x0d
VBAT1S Voltage: 4.750V
read reg 0x54 (PVDD_MSB): 0x31
read reg 0x55 (PVDD_LSB): 0x8d
PVDD Voltage: 12.375V
Load: 9675.9 Ohm
***** Playing diagnostic tone
wrote reg 0x02 value 0x1d, read back 0x1d
read reg 0x02 (MODE_CTRL): 0x1d
read reg 0x44 (INT_LIVE1_0): 0x11
read reg 0x49 (INT_LTCH0): 0x04
read reg 0x4a (INT_LTCH1): 0x22
read reg 0x4b (INT_LTCH1_0): 0x39
read reg 0x53 (VBAT_LSB): 0x08
read reg 0x55 (PVDD_LSB): 0xa2
PVDD Voltage: 12.406V
Load: 9675.9 Ohm
***** Shutting down
wrote reg 0x02 value 0x1a, read back 0x1a
# Integrated system (diagnostic beep works, but then no sound)
***** Resetting
Load: 764174.9500000001 Ohm
read reg 0x4a ( ): 0x22
read reg 0x4b (INT_LTCH1_0): 0x30
read reg 0x4f (INT_LTCH2): 0x08
read reg 0x53 (VBAT_LSB): 0x01
read reg 0x54 (PVDD_MSB): 0x51
read reg 0x55 (PVDD_LSB): 0x80
PVDD Voltage: 20.375V
***** Shutting down
  • Hi Stephen,
    I think the issue is that the I2C Address is set as 0x7e, but register 0x0A is not being written. by default TAS2780 will read data from the I2S slot that is equal to its I2C address offset. In your case the device is looking for I2S data in time slot 8. Can you change register 0x0A to "mono Left/Right channel" this will make the device read from slots 0/1.
    Since there are no interrupts being latched I think that there is no critical issue with your design.
    I.E.
    0x70 - Slot 0
    0x72 - Slot 1
    0x7E - Slot 8
    Arthur
  • Hi Arthur,
    thanks for your quick response!
    I had played with the TDM_CFG2 register before and I can confirm that this is not the issue here. I've set it to LeftRight/2 now right after resetting the chip.
    I see there are interrupts latched (scroll down in the quoted output above). I have made another comparison, printing INT_LIVE and INT_LTCH from the kernel driver right after reset and also in the mute/unmute function which is triggered when playing a sound:
    register comparison
    It looks like there is a VBAT1S under voltage on the integrated system. How is that possible when VBAT1S is generated internally?
    Thanks for your help,
      Stephan
  • Hi Stephan,
    Thank you for pointing that out. I did not see that interrupt.
    When VBAT1S LDO undervoltage flag is thrown for internally generated VBAT this means that LDO did not come up successfully.
    this can happen if there is too much de-coupling on VBAT pin. essentially the current needed to charge 10uF can stop the LDO from coming up.
    On the EVM J13 should be inserted when VBAT1S is external, and removed when VBAT1S is generated internally.
    Can you replace C610 in your schematic with a 1uF capacitor and see if you get this same error?
    Arthur
  • Hi Arthur,
    thanks for finding that!
    After removing C610 (I don't have a 1uF capacitor at hand to replace it with), the registers look the same as on the dev system:
    [58836.892622] tas2780 2-003f: Status in tas2780_mute (mute 0, direction 0):
    [58836.902813] tas2780 2-003f: TAS2780_MODE_CTRL: 0x1A
    [58836.912167] tas2780 2-003f: TAS2780_CHNL_0: 0xE8
    [58836.916948] tas2780 2-003f: TAS2780_DC_BLK0: 0xA1
    [58836.921872] tas2780 2-003f: TAS2780_INT_LIVE0: 0x00
    [58836.926914] tas2780 2-003f: TAS2780_INT_LIVE1: 0x00
    [58836.931974] tas2780 2-003f: TAS2780_INT_LIVE1_0: 0x00
    [58836.937200] tas2780 2-003f: TAS2780_INT_LIVE2: 0x00
    [58836.942301] tas2780 2-003f: TAS2780_INT_LIVE3: 0x00
    [58836.947344] tas2780 2-003f: TAS2780_INT_LTCH0: 0x00
    [58836.952414] tas2780 2-003f: TAS2780_INT_LTCH1: 0x22
    [58836.957453] tas2780 2-003f: TAS2780_INT_LTCH1_0: 0x19
    [58836.962691] tas2780 2-003f: TAS2780_INT_LTCH2: 0x00
    [58836.967729] tas2780 2-003f: TAS2780_INT_LTCH3: 0x00
    [58836.972785] tas2780 2-003f: TAS2780_INT_LTCH4: 0x06
    However, we don't get sound output. Is INT_LTCH4=0x06 a problem? The dev system shows that as well but sound works fine there.
    Do you have any hint on how to debug further?
    Thanks!
      Stephan
  • Hi Stephan,
    I looked into your code again and I do not see you sending the power up command after entering power mode 2.
    Can you confirm that you are sending the  normal_powerup(): command?
    Arthur
  • Hi Arthur,
    we reworked another board and that worked fine. So something must have been broken on the first board.
    Thanks again!
    Stephan
