Hi team,
I'm testing TLV320ADC5120 EVM for my customer.
My input is 0.93Vrms 200Hz sin tone signal, I use single end AC coupled input. I use audacity record the input signal.
I expect to see the data about -1dB, however, it show only -22dB. When I increase the input signal, and I could it can only increase to ~-20dB, and then clip will happen.
I tried several board, all the the same output.
The attached is my config file and the record file. could you help check why this happen and how to fix it?
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/6/TLV320ADC5120-record-file.ppc3
Thanks and Best Regards,
Will
