Switching frequency for the TPA3106D1
Other Parts Discussed in Thread: TPA3106D1
Hello
I'm using the TPA3106D1 in a Master/Slave setup for a stereo configuration and I have 2 questions.
1.  If I'm using hard set resistors to set the Gain inputs, can I use the Vreg from one amp as the power supply for these resistors which will set the gains for both amps?  Or should I have separate gain resistors for on each amp chip, using their individual Vreg supplies?
2. Refering to the switiching frequency set by ROSC, does it become unstable if ran outside of the 200-300 khz window as sugguested in the data sheet?  Also, why does the ROSC resistor have to be populated on the slave amp, and does the value matter for the slave amp?
