Part Number: OPA1656
Other Parts Discussed in Thread: OPA1642
Hi Experts,
Gerald
Hi Experts,
Hi Gerald,
Would it be possible to post a detailed schematic?
The OPA1656 (gain bandwidth product, GBW=53-MHz) and OPA1642 (GBW = 11-MHz) have a different bandwidth and we would need analyze the complete audio active crossover circuit to analyze stability and determine the issue.
Thank you and Regards,
Luis
Hi Luis,
I already requested for it with the customer and he might be able to provide it to us next week. I will send update here as soon as I received it. Thank you.
Gerald
Hi Luis,
Hey Gerald,
Thank you for the schematic. If you are able to provide component values we can analyze this circuit in TINA Ti for stability and recommend solutions to use the OPA1656. I was unable to find the product information for the LM4558. Do you have a link for this product to look at the product datasheet?
Chris Featherstone
Hi Chris ,
Hey Gerald,
Thank you for providing the datasheet. We suspect that the circuit is marginally stable. The GBW of the LM4558 is 5 MHz which isn't much different from the OPA1642 (GBW = 11-MHz). Since the OPA1656 GBW is much larger, this is the reason we suspect the issue is possibly due to stability.
A possible solution would be to lower the positive feedback capacitors and increase the resistors such that the op amp isn't driving large capacitive loads. By lowering the capacitor values and increasing the resistor values the same frequency response for the filtering could be achieved. The trade off would be noise vs stability. Below, I have highlighted the components that could be adjusted if this the issue. This is just a theory. In the meantime we will wait for the customers feedback on the component values in order to check the stability of each op amp below using the OPA1656.
Chris Featherstone
Hi Chris,
"Hi Chris,
Please be informed of the customer feedback below:
