1) What is procedure to get the value of PBE(cutoff frequency and gain) using I2C?.
2) Which resister address are use for that?
Hi Deepa,
These values are based on DSP coefficients, so the only practical way to obtain them is to use the I2C log in PPC3. Click the I2C button on the bottom of the window, and then click the green button (it will turn red) to turn on logging. PPC3 will then record every I2C interaction. It will update in real time with whatever buttons/numbers you change in PPC3.
Because this feature relies on DSP coefficients, it's not a simple register address, but rather many addresses.
Jeff McPherson
