Part Number: TAS2X63EVM
If I want to set the following parameter: Frequency- 1000Hz, Gain-5dB, Bandwidth -635.8Hz in equalizer band-1 then what will be the I2C command for the same without using PPC3.
Hi Deepa,
There is no practical way of finding the I2C writes without using PPC3. The EQ uses DSP coefficients to program the biquads so it's not very practical to derive the coefficients by hand. For convenience I found the I2C writes for you.
Jeff McPherson
