TAS5751M: Can ADDR be tied directly to ground?
Part Number: TAS5751M
Section 7.6.1.2 indicates that a resistor should be used to pull pin 19 high or low. See page 24 of https://www.ti.com/lit/ds/symlink/tas5751m.pdf?ts=1681193555723.
The EVM shows this on pages 21-23 of https://www.ti.com/lit/ug/slou440/slou440.pdf?ts=1681193762462&ref_url=https%253A%252F%252Fwww.ti.com%252Ftool%252FTAS5751MEVM.
Is it acceptable to tie this pin directly to ground for I2C address of 0x54 if the /FAULT output is not needed?
Thank you!
