TAS5558: TAS5534
Part Number: TAS5558
Hi there, I am using TAS5534 for the audio device. I observed that the rise and fall time for SDA and SCL lines should have a minimum of 20ns based on the data sheet.
However, the results obtained are 2.14ns (SCL) and 2.45ns (SDA) which fall out from the specification. The connection for this I2C is directly from the processor.
Is this scenario acceptable? If no, how to improve for such situation?
Attachments are the waveform measurements from SDA and SCL lines respectively.
Hope to receive your reply soon. Thank you.
