Part Number: TPA3116D2
Hi team,
1. The schematic is as follows, with R9, R18 changing to 75kΩ, R10, R19 is changed to 47kΩ, which means the gain is changed from 26dB to 36dB.
Hi team,
Hi Cherry.
About your questions.
1. When the problem happened, will the fault pin become low?
2. Could gather the waveforms when the problems happened? input/output/fault pin/PWM(before inductor)
It's better to gather both normal and abnormal conditions.
3. Does your side have our EVM board? Can you reproduce this on our EVM, this can help us to quickly find the root cause.
BR.
Wei Qiu.
