Hi team,
The customer uses the ibs model simulation provided by TI. The DATA signal of the simulation signal TDM found that the voltage of the DATA signal was low. After the customer's investigation, it is found that there may be a problem with the threshold of the input voltage. Do you have a 3v3 model? This value is not modified by clients.
(The customer tried to disconnect the poweric, and the voltage was normal after disconnection. Due to this model, the customer simulated power consumption)
