I'm designing a device that uses the SHUTDOWN function on this chip to suppress noise coming from other circuits. By shutting down the amp, these noises are not heard in the speaker.
Now my problem is that when I enable the amp by pulling the SHUTDOWN pin low, it gives a loud POP in the speaker which I wanted to avoid in the first place.
Is there any way to remove this loud POP or reduce it significantly?
