I was working in Pure Path 3, saved my file and then a couple hours later tried to reopen the file and I received this message.
"The selected PPC3 file is created with the Process-Flow which is not supported by the current versions of the App (V3.1.12) and cannot be opened".
I did not change or update PurePath or the module for the TAS5825M in between working on and then saving the file, to now trying to open it.
I have made other files since using the same process flow and they are still working fine.
This has happened to me in the past, but I was just starting out setting on the configuration and just remade the file. This time I have spent a lot more time and would like to see about if I can recover the file somehow.
Thanks.
