Part Number: TAS5828M
Hi team,
What is the difference in operation when the SRC control panel in PPC3 is set to [As Input][44.1kHz][48kHz]?
Shunsuke Yamamoto
Hi team,
Shunsuke Yamamoto
hi yamamoto-san
Bass sampling rate means the process sampling rate in DSP.
so as input means process the signal with the sampling rate same with input sampling rate.
44.1khz, 48khz mean processing signal with corresponding sampling rate no matter input sampling rate.
tks
jesse
Hi Jesse,
Thank you for the reply. What is the pros and cons of 44.1kHz and 48kHz of base sampling rate?
Shunsuke Yamamoto
hi yamamoto
no big different between them.
it depends customer's soc can provide what kind of sampling rate data.
tks
jesse
