TLV320AIC3106: m_read:2221: read error: Input/output error
Part Number: TLV320AIC3106
Hi Audio Forum, I'd like to share my problem when I moved device tree and kernel from linux 4.14 to 5.15.
I'm using am335xx as base and have TLV320AIC3106 codec. Previously I was using yocto dunfell with kernel 4.14 I didn't have any problem with these device tree configurations.
    regulators {
    	compatible = "simple-bus";
    	vcc3v3: fixedregulator@1 {
    		compatible = "regulator-fixed";
    		regulator-name = "vcc3v3";
    		regulator-min-microvolt = <3300000>;
    		regulator-max-microvolt = <3300000>;
    sound {
    	compatible = "ti,da830-evm-audio";
    	ti,model = "AM335x-EVM";
    	ti,audio-codec = <&audio_codec>;
    	ti,mcasp-controller = <&mcasp0>;
    	ti,codec-clock-rate = <12000000>;
    	ti,audio-routing =
    		"LINE1L",               "Line In",
    		"LINE2L",               "Line In",
    		"LINE1R",               "Line In",
    		"LINE2R",               "Line In";
    	clocks = <&mcasp0_fck>;
    	clock-names = "mclk";
&i2c0 {
	audio_codec: tlv320aic3106@18 {
		compatible = "ti,tlv320aic3106";
		reg = <0x18>;
		ai3x-micbias-vg = <0x0>;
		status = "okay";
&am33xx_pinmux {
	audio_pins: pinmux_audio {
		pinctrl-single,pins = <
			AM33XX_IOPAD(0x9AC, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* mcasp0_ahclkx.mcasp0_ahclkx */
			AM33XX_IOPAD(0x990, PIN_INPUT_PULLDOWN | MUX_MODE0)  /* mcasp0_aclkx.mcasp0_aclkx */
			AM33XX_IOPAD(0x994, PIN_INPUT_PULLDOWN | MUX_MODE0)  /* mcasp0_fsx.mcasp0_fsx */
			AM33XX_IOPAD(0x998, PIN_INPUT_PULLDOWN | MUX_MODE0)  /* mcasp0_axr0.mcasp0_axr0 */
			AM33XX_IOPAD(0x9A8, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* mcasp0_axr1.mcasp0_axr1 */
&mcasp0 {
	status = "okay";
	pinctrl-names = "default";
	pinctrl-0 = <&audio_pins>;
	op-mode = <0>;	/* MCASP_ISS_MODE */
	tdm-slots = <2>;
	serial-dir = <
		2 1 0 0
	tx-num-evt = <2>;
	rx-num-evt = <2>;
and I can use aplay in order to capture sounds
# aplay -vvv -C -D hw:0,0 -r 16000 -f S16_LE -c 2 /tmp/a.wav
Recording WAVE '/tmp/a.wav' : Signed 16 bit Little Endian, Rate 16000 Hz, Stereo
Hardware PCM card 0 'AM335x-EVM' device 0 subdevice 0
Its setup is:
  stream       : CAPTURE
  access       : RW_INTERLEAVED
  format       : S16_LE
  subformat    : STD
  channels     : 2
  rate         : 16000
  exact rate   : 16000 (16000/1)
  msbits       : 16
  buffer_size  : 8000
  period_size  : 2000
  period_time  : 125000
  tstamp_mode  : NONE
  tstamp_type  : MONOTONIC
  period_step  : 1
  avail_min    : 2000
  period_event : 0
  start_threshold  : 1
  stop_threshold   : 8000
  silence_threshold: 0
  silence_size : 0
  boundary     : 2097152000
  appl_ptr     : 0
  hw_ptr       : 0
Max peak (4000 samples): 0x000000d0 #                    0%
Max peak (4000 samples): 0x000000f1 #                    0%
Max peak (4000 samples): 0x000000d4 #                    0%
Max peak (4000 samples): 0x000000d6 #                    0%
Max peak (4000 samples): 0x000000db #                    0%
Max peak (4000 samples): 0x000000d2 #                    0%
Max peak (4000 samples): 0x0000017d #                    1%
Max peak (4000 samples): 0x0000013e #                    0%
Max peak (4000 samples): 0x00000154 #                    1%
Max peak (4000 samples): 0x00000149 #                    1%
Max peak (4000 samples): 0x00000160 #                    1%
lsmod:
~# lsmod
Module                  Size  Used by
cn                     16384  1
snd_soc_evm            16384  1
snd_soc_davinci_mcasp    24576  2
snd_soc_tlv320aic3x    49152  1
snd_soc_edma           16384  1 snd_soc_davinci_mcasp
snd_soc_omap           16384  1 snd_soc_davinci_mcasp
snd_soc_core          118784  5 snd_soc_davinci_mcasp,snd_soc_edma,snd_soc_evm,snd_soc_omap,snd_soc_tlv320aic3x
snd_pcm_dmaengine      16384  2 snd_soc_omap,snd_soc_core
snd_pcm                81920  6 snd_soc_davinci_mcasp,snd_pcm_dmaengine,snd_soc_omap,snd_soc_core,snd_soc_tlv320aic3x
snd_timer              28672  1 snd_pcm
snd                    49152  4 snd_timer,snd_soc_core,snd_pcm
soundcore              16384  1 snd
cpufreq_dt             16384  0
cryptodev              45056  0
The things are changed when we tried to use latest simple-audio-card driver.
	regulators {
	sound {
		compatible = "simple-audio-card";
		simple-audio-card,name = "snd-ddi";
		simple-audio-card,widgets =
			"Line", "Line In";
		simple-audio-card,routing =
		simple-audio-card,format = "i2s";
		simple-audio-card,bitclock-master = <&sound_codec>;
		simple-audio-card,frame-master = <&sound_codec>;
		simple-audio-card,mclk-fs = <32>;
		sound_cpu: simple-audio-card,cpu {
			sound-dai = <&mcasp0>;
		sound_codec: simple-audio-card,codec {
			sound-dai = <&tlv320aic3106>;
&i2c0 {
	tlv320aic3106: tlv320aic3106@18 {
		#sound-dai-cells = <0>;
		reg = <0x18>;
		status = "okay";
		/* Regulators */
		AVDD-supply = <&vcc3v3>;
		IOVDD-supply = <&vcc3v3>;
		DRVDD-supply = <&vcc3v3>;
		DVDD-supply = <&vdig1_reg>;
&vdig1_reg {
	regulator-boot-on;
	regulator-always-on;
&mcasp0 {
	status = "okay";
	pinctrl-0 = <&mcasp0_pins>;
	tdm-slots = <2>;
	serial-dir = <
		2 1 0 0
	tx-num-evt = <2>;
	rx-num-evt = <2>;
  for this dts, I always get pcm_read error
~# lsmod
Module                  Size  Used by
snd_soc_simple_card    16384  1
snd_soc_simple_card_utils    20480  1 snd_soc_simple_card
snd_soc_davinci_mcasp    28672  2
snd_soc_ti_udma        16384  1 snd_soc_davinci_mcasp
snd_soc_ti_edma        16384  1 snd_soc_davinci_mcasp
snd_soc_ti_sdma        16384  1 snd_soc_davinci_mcasp
snd_soc_tlv320aic3x_i2c    16384  1
snd_soc_tlv320aic3x    53248  1 snd_soc_tlv320aic3x_i2c
snd_soc_core          147456  7 snd_soc_davinci_mcasp,snd_soc_simple_card_utils,snd_soc_ti_sdma,snd_soc_ti_edma,snd_soc_tlv320aic3x,snd_soc_ti_udma,snd_soc_simple_card
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_pcm                94208  5 snd_soc_davinci_mcasp,snd_pcm_dmaengine,snd_soc_core,snd_soc_tlv320aic3x
snd                    57344  4 snd_timer,snd_soc_core,snd_pcm
cfg80211              307200  0
cpufreq_dt             16384  0
~# aplay -vvv -C -D hw:0,0 -r 16000 -f S16_LE -c 2 /tmp/a.wav
Hardware PCM card 0 'snd-ddi' device 0 subdevice 0
Its setup is:
  stream       : CAPTURE
  format       : S16_LE
  subformat    : STD
  channels     : 2
  rate         : 16000
  msbits       : 16
  buffer_size  : 8000
  period_size  : 2000
  tstamp_mode  : NONE
  period_step  : 1
  avail_min    : 2000
  period_event : 0
  start_threshold  : 1
  silence_size : 0
  appl_ptr     : 0
  hw_ptr       : 0
arecord: pcm_read:2221: read error: Input/output error
What do you suggest in order to investigate problem and solve it? I used here as reference: https://git.phytec.de/linux-mainline/tree/arch/arm/boot/dts/am335x-wega.dtsi?h=v5.15.82-phy
Every answer is welcomed, and many thanks
  • Kindly measure the i2s clk(bck/ws clk) with scope during recording. and post the clk waveforms. Thanks.
  • Hi , I did measurement.
    I've realized that there are clock ticks on old device tree only. New implementation is always 0.
    old_ wclk:
    old_mlck:
    old_bclk:
    new_mclk:
    new_mclk:
    I'm using same clocks but couldn't understand why it's not driven.
  • I've made some changes this after phytec feedback on clock definition and now I'm able to record some sounds but I'm not confident about correctness of it. How should I select mclk-fs value?
    sound {
    			"Line", "Line In";
    		simple-audio-card,bitclock-master = <&sound_cpu>;
    		simple-audio-card,frame-master = <&sound_cpu>;
    		simple-audio-card,mclk-fs = <512>;
    For the dts setting posted in the thread, it seemed that mcasp0 has been set as master, kindly consult am335xx team. Thanks.
