TAS2780: I encountered an error, but do not know how to solve it
Part Number: TAS2780
From the error log, it seems that the problem is i2c.However, the other peripherals below my i2c can communicate normally
    Pls make sure the hardware connection is fine. Then use following commands:
    i2cdump -y -f 0 0x38
    0 is i2c bus no
    0x38 is 7-bit i2c device address
    One more thing, what the 7-bit i2c address on your device? It seemed 0x70, this address is so strange,
    kindly check the datasheet and hardware engineer.
