Where can I get the docs on the eval board? Mine has a 3 way dip switch and a load of test ponts. It must be a revised version of the evaluation design.
Apart from the DEM-PCM2912AEVM it has AMPS149A on the underside.
Hi Geoffrey,
You're right. The user guide wasn't updated for some reason. I've attached the new schematic below.
DEM-PCM2912AEVM B Rev. Schematic.PDF
The advice in the user guide is still applicable. The only difference is that the 3 way switch replaces the old SW1, JP1, and JP2. The schematic also highlights which switch position applies to which feature.
Jeff McPherson
