TAS5754M: TAS5754M
Part Number: TAS5754M
Hi,Sir.
Can GPIO2 of TAS5754 be set to TDM output and used together with 2 GPIO2 of TAS5754? If not, is there a chip that converts 2 I2S (TDM) to 1 TDM output?
Thanks!
  • Hi Huiquan
       In TAS5754 datasheet, there's seems not a register could specially set the offset of SDOUT signal in TDM mode. So it's quite possible you can't mix two device's SDOUT into one line, because they may take up the same slot position, the data conflict each other.
