TAS6584-Q1: Invalid temp readings on startup
Part Number: TAS6584-Q1
Hi there,
I am running into a strange bug with the TAS6584 where on power up, its temperature readings return -273.13C (or register value 0) and doesn't update until a load is connected. Only after the load is connected does the temperature register update properly. Is this normal behavior?
Thanks in advance,
Yutong
