I've connected the TLV320AIC3104IRHBR's LEFT_LOP/M to the TPA2011D1YFFT and set the Gain to 2V/V.
The LEFT_LOP/M outputs 4Vp-p, but the TPA2011D1YFFT only outputs 6Vp-p.
Please assist me in reviewing the schematic to identify the issue.
Hi Kungyeh,
Could you please comment where are you measuring the signal between CODEC and amplifier? Is it before or after R204/R206? I wonder if these resistors could load down the signal before getting to the amplifier inputs.
As part of debugging, you may try replacing R204/R206 with 0Ohm.
-Ivan Salazar
Applications Engineer
