Part Number: TPA3255EVM
Other Parts Discussed in Thread: TPA3255
Hello Team,
Could you kindly explain the technical distinctions between the TPA3255EVM and TPA3255D2EVM?
Pavan P
Hello Team,
Pavan P
Hello team,
Could you please confirm, that only name change is the difference between two boards i.e.,TPA3255EVM and TPA3255D2EVM .
We have previously ordered TPA3255D2EVM board for evaluation, Now, given its current unavailability, we wanted to order new EVM, so we would like to assess whether there are any technical differences between the two boards.
Thank you
Hi Pavan
In our hand and normal using, there's only TAS3255EVM, only this one version. It's quite easy to use, and have User Manu as guidance. Maybe needn't to worry about it.
The whole schematic and BOM are in the Manu, maybe you could check and see if anything to worry about.
And if you have more information about the TPA3255D2EVM you mentioned, like the schematic, could send it to me. I'll check if there any difference need to take care.
Hello Pavan,
For the TPA3255D2EVM did the board have the Label AAP053E1 or AAP053E2? When the device was RTM'd we only released a TPA3255EVM which has an AAP053A, those other boards are likely preproduction during the development of the part.
best regards,
Luis
Hello Pavan,
The AAP0053B is the latest revision of the TPA3255 EVM so shouldn't be any concerns there.
best regards,
Luis
