Part Number: TLV320AIC3105
Other Parts Discussed in Thread: TLV320AIC23B, , TLV320AIC3204
We are replacing the discontinued TLV320AIC23B on several circuit boards. I am looking at the TLV320AIC310x series of CODECS. A major difference, though, is that the line out is differential instead of single-ended as in our older part (AIC23B). Can the + output on the AIC310x be treated as single-ended or do we also need to replace the following op-amp (TPA701D) with a differential to single-ended amplifier? Conversely is there a low-cost codec with single-ended line outputs?
