Part Number: PCM1808
Hi Team,
I have a question regarding the Analog Input Voltage. When our DUT (Device Under Test) is in idle mode, an input signal activity on VinL and VinR can be generated. During this activity, the signal can go as low as -628.59mV.
Does TI PCM1808 chip okay to have this -628.59mV signal on VinL or VinR input pin?
See below for the plots.
Note: All signals below are measured on the pin of the Chip.
Thank you for your time!
