Other Parts Discussed in Thread: TDA4VM
HI,TI
We are debugging TLV320AIC3109 on our TDA4VM board. The driver refers to tlv320aic3x.c and we modified the corresponding register according to the chip specification.
Codec working on slave mode, right-justified timing, route to HPCOM/HPOUT and LEFT/RIGHT_LOM/LOP. Now we found that codec have no output when playing music. We measured the bit clock, word clock, and data, and they are all correct. The value of the register is shown below when playback.
81450 16:31:34 [ 475.230974] tlv320--aic3x_mute--audio test--reg94:0x00 [ 475.236104] tlv320--aic3x_mute--audio test--reg95:0x00 [ 475.241235] tlv320--aic3x_mute--audio test--reg96:0x00 [ 475.246361] tlv320--aic3x_mute--audio test--reg97:0x00 [ 475.251486] tlv320--aic3x_mute--audio test---------------------------------------------------- [ 475.260081] tlv320--aic3x_mute--audio test--reg81:0xaf [ 475.265208] tlv320--aic3x_mute--audio test--reg82:0xaf [ 475.270335] tlv320--aic3x_mute--audio test--reg84:0xaf [ 475.275461] tlv320--aic3x_mute--audio test--reg86:0x01 [ 475.280586] tlv320--aic3x_mute--audio test--reg88:0xaf [ 475.285719] tlv320--aic3x_mute--audio test--reg89:0xaf [ 475.290853] tlv320--aic3x_mute--audio test--reg91:0xaf [ 475.295981] tlv320--aic3x_mute--audio test--reg93:0x01 [ 475.301106] tlv320--aic3x_mute--audio test---------------------------------------------------- [ 475.309698] tlv320--aic3x_mute--audio test--reg34:0x00 [ 475.314824] tlv320--aic3x_mute--audio test--reg36:0x00 [ 475.319949] tlv320--aic3x_mute--audio test--reg37:0xc0 [ 475.325075] tlv320--aic3x_mute--audio test--reg38:0x00 [ 475.330200] tlv320--aic3x_mute--audio test--reg39:0x00 [ 475.335326] tlv320--aic3x_mute--audio test--reg40:0x40 [ 475.340452] tlv320--aic3x_mute--audio test--reg41:0x00 [ 475.345579] tlv320--aic3x_mute--audio test--reg42:0x00 [ 475.350708] tlv320--aic3x_mute--audio test--reg43:0x2f [ 475.355834] tlv320--aic3x_mute--audio test---------------------------------------------------- [ 475.364427] tlv320--aic3x_mute--audio test--reg60:0xaf [ 475.369553] tlv320--aic3x_mute--audio test--reg61:0xaf [ 475.374680] tlv320--aic3x_mute--audio test--reg63:0xaf [ 475.379806] tlv320--aic3x_mute--audio test--reg65:0x58 [ 475.384932] tlv320--aic3x_mute--audio test--reg67:0xaf [ 475.390063] tlv320--aic3x_mute--audio test--reg68:0xaf [ 475.395192] tlv320--aic3x_mute--audio test--reg70:0xaf [ 475.400322] tlv320--aic3x_mute--audio test--reg72:0x58 [ 475.405450] tlv320--aic3x_mute--audio test---------------------------------------------------- [ 475.414045] tlv320--aic3x_mute--audio test--reg8:0x20 [ 475.419086] tlv320--aic3x_mute--audio test--reg9:0x80 [ 475.424125] tlv320--aic3x_mute--audio test--reg10:0x00 [ 475.429251] tlv320--aic3x_mute--audio test--reg11:0x01 [ 475.434376] tlv320--aic3x_mute--audio test--reg12:0x00 [ 475.439502] tlv320--aic3x_mute--audio test--reg13:0x00 [ 475.444628] tlv320--aic3x_mute--audio test--reg14:0x00 [ 475.449756] tlv320--aic3x_mute--audio test--reg15:0x2f [ 475.454883] tlv320--aic3x_mute--audio test--reg16:0x2f [ 475.460009] tlv320--aic3x_mute--audio test--reg19:0x00 [ 475.465133] tlv320--aic3x_mute--audio test--reg21:0x78 [ 475.470260] tlv320--aic3x_mute--audio test--reg22:0x00 [ 475.475387] tlv320--aic3x_mute--audio test---------------------------------------------------- [ 475.483980] tlv320--aic3x_mute--audio test--reg26:0x00 [ 475.489105] tlv320--aic3x_mute--audio test--reg27:0xfe [ 475.494231] tlv320--aic3x_mute--audio test--reg28:0x00 [ 475.499357] tlv320--aic3x_mute--audio test--reg32:0x18 [ 475.504484] tlv320--aic3x_mute--audio test---------------------------------------------------- [ 475.513080] tlv320--aic3x_mute--audio test--reg0:0x00 [ 475.518254] tlv320--aic3x_mute--audio test--reg1:0x00 [ 475.523299] tlv320--aic3x_mute--audio test--reg2:0x00 [ 475.528340] tlv320--aic3x_mute--audio test--reg3:0x10 [ 475.533381] tlv320--aic3x_mute--audio test--reg4:0x04 [ 475.538424] tlv320--aic3x_mute--audio test--reg5:0x00 [ 475.543462] tlv320--aic3x_mute--audio test--reg6:0x00 [ 475.548500] tlv320--aic3x_mute--audio test--reg7:0x98
So How can we check the working status of the codec? such as whether data is received and correctly parsed. We will be very pleased if you can provide register configuration of codec.
Zhang
