Other Parts Discussed in Thread: DIX4192,
Hi All,
I had few doubt related to DIX4192 IC
1) Master clock and RXCKI can be shorted together or RXCKI can it be left Floating?
2) DIX4192EVM-PDK uses Optical input and is controlled by single RX4+ what about pin status about RX4- .Single connection for RX4 + is enough. If possible can you suggest the alternate part for the TORX179PL this part is obsolete
3) BLS pin requires PULL down if not used ?
